rsx seats into ek hatch
well im not sure if this is out there or not cause i tried to find it with no luck but anyway just did rsx type s seats in my 96 hatch its not as hard as most people make it out to be all i did was for the front was cut the welds where the bolts go and simply turned the mount around and lengthin the bolt hole closest to the center console on the back and then u just need a longer bolt for the other side and ur done with the front
now for the back this really only took bout 15-20 min. just unbolt the old seats and bolt the new one up on the bottom half the rsx seats snaps in the rsx well it dont snap into the civic i just drilled a hole and bolted it no prob and for the top half all u need is to bolt em in the only part that needs to be swaped is the plastci sleeve that goes between the seats where it pivots and thats it ur done hopefully this will help some one cause i know i had a hard time finding the info.
Re: rsx seats into ek hatch
well thanks for that i guess didnt really need help anymore and u dont have to do nearly that much to make the seats work plus the way i did it its a much cleaner end result no random brackets screwed together no offense to who did that but there is a better way to do it though and i thought people would want to know
wushubrian
03-11-2005 10:17 AM
