RPMs going up and down
Old 02-04-2014, 05:09 PM
pxlds's Avatar
Default RPMs going up and down
so ive noticed when starting my civic the rpms go below zero so i have to heat it up for more than 10 mins up to when the temperature meter is almost at the 3rd bar then when im running it it stays a little over 1 and when i turn my ac on it goes back down but attempts to turn of in the process of slowing down ? ive heard so many things but wanna know what it really is and if there 2 different problems or just one simple one thats causing all this wreckage.
Old 02-04-2014, 05:28 PM
Hysterically Calm
TomCat39's Avatar
Default Re: RPMs going up and down
Pulled from the rules stickied at the top of this forum.
Car information
For all technical questions, the following information MUST be included in the first post: vehicle (year, make, model) and engine (if not stock, year, make, model, OBD type). Other pertinent information includes check engine light (CEL) codes as well as engine modifications, such as a turbo kit tuned at 18 psi or a specific throttle body, large injectors, big cams, etc. This information is absolutely essential because, in many instances, members wishing to help in a thread waste their time by posting detailed replies, only to find out the next day that the topic starter left out CRITICAL information. Please respect members wishing to help by taking the time to list or mention crucial information about your car.
Old 02-04-2014, 06:28 PM
street_racer_271's Avatar
clean your IAVC, its on the back of you manifold. If you have unplugged any sensors, chances are you have that mixed up with another one.
Old 02-04-2014, 08:27 PM
crazyhouse2011's Avatar
I'm not sure what that means, but I know that engines can't spin negative revolutions...
Old 02-05-2014, 01:30 AM
anthonyelectric's Avatar
Sounds odd, but my neighbor had a honda with this issue and just made sure the coolant was topped off to the correct level. RPMs steadied out.
Old 02-05-2014, 01:34 AM
Technical Hero
HondaPartsHero's Avatar
Check your coolant level, sounds like you may be low and possibly have a leak. If so find the leak and bleed your coolant according to the FAQ. You may also need to clean your IACV and FITV as in the FAQ as well.
Old 02-05-2014, 02:49 AM
Effin-Jay's Avatar
Could be the tps as well..check the voltage,if u have poly mounts it could have worked it lose. And also try turning down your idle,that helped mine.
Old 02-05-2014, 05:40 AM
SeVeNisOnE's Avatar
Could be a possible vacuum leak. Check all hoses associated with vacuum. Also make sure coolant is topped off. When the car is warmed up unplug the IACV. If there is a change in RPM than most likely the IACV needs replacing or a really good cleaning.
Brent.bucher
12-24-2015 01:35 PM
big_jay239b16A
21
05-07-2015 09:13 AM
Ryan Bello
10-24-2014 12:39 PM
707Bay
31
05-31-2014 07:08 PM
Quick Reply: RPMs going up and down
