Rpm gauge flickes up and down and bogs
After changing my igniter module, i noticed that the rpm flickers like staticky.. and when i try flooring 2nd and 3rd it bogs... could it be a bad igniter.. ? HELP!!!! never ending problems!
Re: Rpm gauge flickes up and down and bogs
Yes sirr..as a matter of fact the coil is brand newww..imma double check all the ignitr wires..
First, are you throwing an codes? If so, what are they. If by igniter you mean the ignition control module, it could possibly be bad. Follow the procedure for checking the icm and the coil in the factory service manual. If the electrical checks for the icm and coil are good, follow the procedure for checking the ckp, cyp, and tdc sensors.
It is rather odd that you would have this problem and not be throwing a code, but it does happen from time to time.
I have replacement parts for many obd1 distributors, let me know what you need and I can ship it to you right away. I can also walk you through how to set up the sensors after installation if you need.
I've had this problem before and it is literally a 45 minute fix. That includes troubleshooting to determine the source of the problem.
Naw I'm not throwing n e codes.. and no thanks on the parts I got plenty on parts myself here in my garage.
