Royal Purple
Old 02-17-2010, 02:20 PM
ToTriggerHappy's Avatar
Icon2 Royal Purple
1. Is it good to run in your Honda?
2. How often should I change my oil with Royal Purple?
3. Has anybody had any problems with using Royal Purple?
4. What are the pros and cons?
Just wondering because I am debating weather to run it in my Honda or not. Thanks
Old 02-17-2010, 02:59 PM
90_EX_Civic's Avatar
Default Re: Royal Purple
1. yes
2. depends
3. yes, but not for me. have heard other people having problems
4. pros: does what it's meant for
cons: expensive
other stuff out there that are cheaper and work the same.
Old 02-17-2010, 04:38 PM
SimpleAznMan's Avatar
Just stick with Mobil1 Clean 5000 or Honda oil... (I say Mobil1 because ExxonMobil produces oil for Honda)
Old 02-17-2010, 05:28 PM
alright...thanks man
Old 02-17-2010, 06:14 PM
There was an article awhile back... They asked the Honda CEO what oil would run best for Honda vehicles... his exact words were to just stick with Honda oil... even when people asked him if they should run synthetic or conventional. The chemical balance/structure was designed specifically for your car and you can't go wrong with it if it came out of the factory with it. Do your oil change every 3000-5000 miles, use Honda filter or K&N filter or Mobil1 filter... and Honda oil or Mobil1 Clean 5000 oil.
Heres a big tip, Honda oil costs more because it has the Honda label on it... and dealerships need to make money. As I said earlier, ExxonMobil produces oil for Honda... The gallon jug at walmart for Mobil Clean 5000 5W-30 is wayyyyy cheaper :D
Old 02-17-2010, 06:57 PM
jdmdc2t3g's Avatar
I use to run Royal Purple in my ls/VTEC cause you could just tell it was sooo much better than what I used before that (Castrol Syntec). But then I heard of alot of people's bearings getting to hot with Royal Purple so I switched to Mobile 1. Won't use anything else...
x2 on the jug at wal mart! In north east KS, O'rielly's sells 4 qt. jugs of Mobil 1 for ~$27. At wal mart, a 5 qt jug is $23! LOL...
Old 02-17-2010, 07:15 PM
300whpej's Avatar
i have used mobil 1 for years, the 5+ qt jug runs me about 17
Old 02-17-2010, 07:22 PM
JasonYo's Avatar
I just use mobil 1, it goes on sale often at the store, its like $30can for 4.4 litres.
And I also can't get royal purple where I live, they don't sell it in the province anymore.
Old 02-21-2010, 07:23 AM
i just bought some mobil1 and i will let yall know how i like it aft my rebuild
Old 02-23-2010, 05:18 PM
jdmdc2t3g's Avatar
fml... thought i was getting a steal.
Old 02-23-2010, 06:35 PM
kct01's Avatar
I use rp for over a few years now and no problem I use it in my gsr and eg h22a. I use to use castrol untill I used rp and it restored my loss hp more then castrol, not saying castrol is bad but it's good for it's money spent-also castrol syntec blend only contains 10% syntectic.
Old 02-23-2010, 07:29 PM
doosua's Avatar
Thanks for the info. Guys!
Old 02-23-2010, 07:56 PM
mikej94civex's Avatar
over 70k just use penzoil 5w-30 high mileage, with napa engine restorer, works wonders!!
Old 02-23-2010, 09:48 PM
x2
Old 02-23-2010, 10:23 PM
boxeocampeon's Avatar
def mobil 1 its good *** oil. dont run royal purple unless your running a highly modified engine
Old 02-23-2010, 11:53 PM
94_DC's Avatar
http://www.animegame.com/cars/Oil%20Tests.pdf
Old 02-24-2010, 04:11 AM
Reject Papi
jhammond_82's Avatar
autozone always has a sale on oil. like, 12 bucks for 5 quarts and a filter. i got mobile1 5000 oil and an stp filter for 14.99 last time i did my oil change. not too bad i don't think. and 3 months ago in muscel mustang and fast fords, there was an article comparing all the top brands of oil. autozone brand made .5 MORE hp than the 30-40 dollar oils did. i've used supertech in lots of cars and never had any problems with it.
Old 02-24-2010, 04:29 AM
apexi_rsx's Avatar
the Stealership uses Castrol Oil so thats what i use.... i dont know where you get this mobile 1 nonsense. castrol edge is suposed to be better then mobil 1 now..... its oil as long as u change synthetic every 2k and convention oil ever 3k you should be fine.
Old 02-24-2010, 05:14 AM
Jimster480's Avatar
why would you change synthetic more often than conventional? especially when synthetic has alot more resistance to heat than conventional.
Old 02-24-2010, 05:38 AM
kct01's Avatar
synthetic lasts few more thousand miles then convention.
94_DC Re: Royal Purple
Very good info and proves that no other motor tested other then Penrite synthetic stands up to Royal Purple. I don't know but here in ATL, GA Pep boys are having a sale on RP oil and RP oil filter for $49.95 for 5 QT and filter. Now that's a deal! Honda+Royal Purple oil=
Old 02-24-2010, 06:03 AM
turbodcxbro's Avatar
Wow, there are some minsinformed folks on this one!!
Number 1- Mobile 5000 and Mobil 1 are NOT the same thing!
Mobil 5000- Conventional oil
Mobil 1- Synthetic
You do NOT need to change synthetiics nearly as often as a conventional oil, thats the whole idea behind them, longer change intervals and better wear protection!
Autozone oil producing .5 more hp than any other oil?!?!? C'mon WTF are you smokin? Granted some big oil company is making the oil for them but I highly doubt its a top tier oil.
Mobil 1 is a top tier sythetic oil and has been for many many years, it is a factory fill in many high end cars so think about that... You guys all need to go over to www.bobistheoilguy.com and do some reading!!
Old 02-25-2010, 08:01 PM
Mobil 1- Synthetic
well thanks for the info
Old 02-25-2010, 08:27 PM
nextproject97's Avatar
Motul 300V for me very expensive but awesome oil
Old 02-25-2010, 08:28 PM
peatear01's Avatar
i ran royal purple, in a straight ls with a mild built head, you can tell the difference , but i spun a bearing tearing up two stangs... i'll have to agree, stick with mobil1, its by far the most reliable and doesn't disappoint me, royal purple did...
revbc
02-27-2019 08:53 PM
return_2020
12-25-2004 11:10 AM
X2BOARD
10-07-2004 12:55 PM
georgeda
07-14-2003 11:48 AM
Quick Reply: Royal Purple
