rough cold idle and surging rpms.
Old 03-13-2008, 11:19 AM
bp2007's Avatar
Default rough cold idle and surging rpms.
I'm sure this has been covered or another post but I can't seem to find a solution.
I have a 97 ex(CDN SI). On cold starts she idles rough a little bit then the rpms kick up to almost 2k.
Also after driving a little bit when I'm at a dead stop the rpms surge a bitup about 5pms then back down and it does this 2-3 times.
I've already replaced the iacv, cleaned the map sensor, cts was replaced, new plugs, wires and rotor cap and button and adjusted the valves (I'm sure this ahd nothing to do with the rough idle but it had to be done none the less).
Old 03-13-2008, 11:22 AM
Resident Gearhead
BryanM.'s Avatar
Default Re: rough cold idle and surging rpms. (bp2007)
Vacuum leak?
Old 03-13-2008, 11:27 AM
bp2007's Avatar
no vacuum leaks
Old 03-13-2008, 11:34 AM
Former User's Avatar
Default Re: (bp2007)
You may want to check whether the throttle cable is out of adjustment and whether the throttle body is dirty.
protopro88
04-08-2011 03:41 PM
90Rexx
06-28-2008 06:26 PM
allshownogo
03-09-2008 01:09 PM
takeit
09-11-2007 06:31 PM
Bboy_Trevstuh817
01-07-2007 10:31 PM
Quick Reply: rough cold idle and surging rpms.
