Rota/Hubcentric ring question
Old 05-22-2003, 10:36 AM
Judah's Avatar
Default Rota/Hubcentric ring question
What size rings do I need for my 15" C8s to mount up to my 94 hatch? Also, what's the best place to get them and what type is recomended?
I did a search and only found a few debates about whether or not you need hub rings, but no actually sizes...
TIA
Old 05-22-2003, 10:55 AM
Judah's Avatar
Default Re: Rota/Hubcentric ring question (TypeR895)
Nobody has hubcentric rings on Rotas?
At least where can I call to order a set?
Old 05-22-2003, 10:57 AM
SloCivicHMM's Avatar
I'm sorry but what is the ring for?? I'm cluelesss....i'm running stock rims on mine...
junglerunna's Avatar
When I talked to a guy at http://www.jaydm.com on the phone he said you wouldn't need them on a civic. Now if that is correct or not Im not sure.
Old 05-22-2003, 10:58 AM
B_CRUZ!'s Avatar
Default Re: Rota/Hubcentric ring question (junglerunna02)
you do need them. get them dierctly from Rota(cosmic) or machiii.net.
Old 05-22-2003, 10:59 AM
Default Re: Rota/Hubcentric ring question (BCRUZ)
Why exactly do you need them?
eh3 93's Avatar
try matt @ http://www.1201aeromotiv.com
Old 05-22-2003, 11:00 AM
Judah's Avatar
Thanks
Old 05-22-2003, 11:03 AM
Zer0DazE's Avatar
i got metal ones from Matt when i ordered mine
Old 05-22-2003, 11:04 AM
pdiggitydogg's Avatar
i was lookin at the same problem...i know the inner is 56.15mm for civic but what about outter diameter?
Old 05-22-2003, 11:23 AM
NonovUrbizniz's Avatar
Default Re: Rota/Hubcentric ring question (pdiggitydogg)
call the manufacturer... they'll give you the proper one and where you can get them...
they center the wheel on the hub... some lugs (lugcentric lugs) do the same thing w/o a center ring... however you can run into serious problems w/o them..
I had no hub-centric rings on my sentra with a couple pairs of wheels and there was always weird vibration in the steering wheel over 60 or so (no they did not need to be balanced.. or aligned)... when I put on the hub-centric rings it fixed it immediatly.
Old 05-22-2003, 01:07 PM
ntrinsik's Avatar
I got some hubcentric rings from Prestige Wheel.
http://www.prestigewheel.com/c...-5615
Those were the ones I ended up getting from them. Fit perfectly, and not made of metal or plastic.
Old 05-22-2003, 01:15 PM
tonyxcom's Avatar
Default Re: Rota/Hubcentric ring question (ntrinsik)
The ones I got from Matt say
Ø67 x Ø56.1 M4
These fit my
4x100 only Slips
8x100 C8s
8x100 Rota RNR
I remember Matt telling me that Rotas that are drilled for 100 and 114 have a different center bore.
Old 05-22-2003, 01:23 PM
Nextelbuddy's Avatar
Default Re: Rota/Hubcentric ring question (tonyXcom)
yea the rings help balance out the wheel on the hub so your car doesnt chake on the road when you have greater speed
Old 05-22-2003, 02:17 PM
Default Re: Rota/Hubcentric ring question (nextelbuddy)
I take it we don't need it on stock 15in wheels??
Old 05-22-2003, 02:19 PM
dantastic's Avatar
plastic ones are better than metal. metal ones tend to rust/seize to the hub
Old 05-22-2003, 02:24 PM
tonyxcom's Avatar
Default Re: (dantastic)
And plastic ones tend to melt if you track your car.
Matt stocks aluminum ones.
Old 05-22-2003, 03:08 PM
ntrinsik's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">plastic ones are better than metal. metal ones tend to rust/seize to the hub</TD></TR></TABLE>
Plastic tends to melt or break faster.. go with composite
Old 05-22-2003, 03:47 PM
all stock's Avatar
Default Re: (ntrinsik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ntrinsik &raquo;</TD></TR><TR><TD CLASS="quote">
Plastic tends to melt or break faster.. go with composite </TD></TR></TABLE>
i've been running with some hard plastic crap for over a year now. haven't melted or warped on me yet. lots of people run w/o them, others run with them. depends if u want peace of mind or not.
Old 05-22-2003, 03:49 PM
B_CRUZ!'s Avatar
Default Re: (all stock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all stock &raquo;</TD></TR><TR><TD CLASS="quote">
i've been running with some hard plastic crap for over a year now. haven't melted or warped on me yet. lots of people run w/o them, others run with them. depends if u want peace of mind or not.</TD></TR></TABLE>do you track your car?
I don't mean strait line either...
Old 05-22-2003, 07:39 PM
kommon_sense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ntrinsik &raquo;</TD></TR><TR><TD CLASS="quote">I got some hubcentric rings from Prestige Wheel.
Those were the ones I ended up getting from them. Fit perfectly, and not made of metal or plastic. </TD></TR></TABLE>
I got mine from these guys as well. You don't want metal OR plastic hub rings.
Old 05-22-2003, 11:15 PM
deviant1's Avatar
Will these specific rings fit/work properly on a 96 civic hatch with 16" rota slips/4x100/offset 40 or 42 i think. and how many do i put in the quantity box? does quantity 1 mean it comes with all 4 of them? or is it 7 bux each and i need to put 4 in the quantity box?
do these require special tools to install? or slip it on and bolt on the wheel?
Old 05-23-2003, 07:44 AM
Default Re: Rota/Hubcentric ring question (deviant1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deviant1 &raquo;</TD></TR><TR><TD CLASS="quote">
do these require special tools to install? or slip it on and bolt on the wheel?</TD></TR></TABLE>
Go to prestigewheel and start at the main page. You will see a link for hub rings, then you pick your wheel, then you pick your hub diameter (56.15). You enter 4 in the quantity box.
Old 05-23-2003, 07:46 AM
dantastic's Avatar
come to think of it, mine arent plastic either.... they are composite. light as plastic, but far more brittle. dont look like theyre gonna melt just dont metal ones. theyre a bizznatch to get off
Old 05-23-2003, 07:51 AM
joe_bocc's Avatar
Default Re: Rota/Hubcentric ring question (kommon_sense)
What about 5 lug conversions. Do they need these rings? Do they need to same size or different?
Quick Reply: Rota/Hubcentric ring question
