Roll Bar / Roll Cage
If i have a bolt in roll bar. Which i know does not increase handing at all. And is not NHRA certified. Can i just go to a shop that does roll cages, and just have them cut off where the roll bar bolts in, and have them weld it instead?
Or does a roll cage go to completely different areas? |
say what?
Re: Roll Bar / Roll Cage (Power Rev Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Power Rev Racing »</TD></TR><TR><TD CLASS="quote">If i have a bolt in roll bar. Which i know does not increase handing at all. And is not NHRA certified. Can i just go to a shop that does roll cages, and just have them cut off where the roll bar bolts in, and have them weld it instead?
Or does a roll cage go to completely different areas?</TD></TR></TABLE>Why did you buy the bolt-in in the first place? |
Re: Roll Bar / Roll Cage (Revolver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MichaelJComputer »</TD></TR><TR><TD CLASS="quote">say what?</TD></TR></TABLE>
lol But yea it depends on how and where the bolt in on bolts to. and do you want the cage for looks, or do you plan on road racing, or drag racing? |
Trying to get into road racing.
So want to unbolt the bar, and weld it in instead. |
Check the rules and find out what they require, then see if your cage will be acceptable (after it's welded). If not, look into custom cages etc.
