rod bearings
rod bearings
i ordered all my main and rod bearings from acura as per color code.....i know the part numbers on the mains were different for upper and lower....but according to what they gave me the rod bearings upper and lower are the same.....can that be right? both upper an lower have the hole in them.
Re: (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">rod bearings shouldnt have holes on them like the mains do.</TD></TR></TABLE>
well according to the exploded view posted above from honda they look just like the ones i have and top and bottom do
thanks for all the replies
You sure about that?
Re: (Chiovnidca)
if they didnt have holes in them then how does the oil flow thru the crank into the area between and provide lubercation?
they have holes on both sides because the rod bearings are interchangeable with the tops and the bottoms.
