rocker-arm holder (d16y8 & d16a engines)
hey guys i need some info
okey i want to replace the rocker-arms holders on my d16y8 engine the number 1 & 3 because the previous owner messed up the head cover bolds on 1&3 rocker-arms holder. what i want to know if i can replace it with the one of a d16a engine???
both engines have the same spec except for v-tec the d16a is a non-vtec
both have sohc
thanx
both have sohc
thanx
Re: rocker-arm holder (d16y8 & d16a engines)
D16A has a vtec solenoid, but no actual vtec internals...that's an odd little motor.
Are you talking about the little hollowed out hex head that the rocker arm sits in? It's called the oil passage orifice assembly. They appear to be the same, as far as I can tell from parts catalogs.
the valve cover has 5 bolts right? Those are messedup. And I want to replace the whole rockerarm holder is it possible? Would it damage the rockerarm
Thank u
Thank u
I count five bolts, yes.
So in your first post, you said one of the oil passage orifice assemblies (rocker arm holder) was damaged, too? The rocker arm just sits on top of it - you can easily pull the rocker arm out, remove the oil passage orifice assembly, install a new one, and reinstall your rocker arm. Just make sure you do a valve lash adjustment afterwards.
yeah man thank u. So i can use the one from the d16a right? and where is the vtec-solenoid of the d16a?
thanx in advance
thanx in advance
Yes, you should be able to use the OPOAs from the D16A. I honestly don't know where the solenoid is on the D16A, but I'd imagine it's where they usually are - right in front of the distributor.
whitephish
01-08-2017 07:02 AM
red91g2
12-18-2002 09:12 PM
