risky?
Re: risky? (slowEGchris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowEGchris »</TD></TR><TR><TD CLASS="quote">how risky would it be to turbo my d15b7 with 180k miles on it? like maybe around 6 lbs?</TD></TR></TABLE>
http://home.comcast.net/~fat_tony/BOOST.MOV
I have 193,500 on the clock and peak out around 9 - 10psi with no problems on stock internals (I have done a really good tune on it though). But, it really depends on what kind of condition your engine is in...
a. Does it burn oil?
b. Have you done a leakdown test?
c. Compression test?
I run a hf manifold with a t3 internaly gated turbo, 2.5 in exhaust, 450cc dsm injectors/resistor box, fuel pump, chipped and tuned ecu, and everything else is stock.
Correct me if I am mistaken, but I think that d15 engines hold boost better than d16 do because of a better rod/stroke ratio (although you may not get bigger hp numbers).
If it is a daily driver, you may want to run 7-8psi.
Oh yea, I have a second car just incase I blow this one up.
Re: (hondaz6lx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaz6lx »</TD></TR><TR><TD CLASS="quote">dont be scared its a 200.00 motor</TD></TR></TABLE>
or less.
or less.
Re: risky? (inline4me)
a. Does it burn oil? Nope, doesn't burn oil
b. Have you done a leakdown test?how exactly do you do one?
c. Compression test? can/will do it soon, have the compression tester in my garage somewhere
what it comes down to is.... I am always low on money so would it be a better choice to just be patient and save and just get maybe an ls or gsr and boost it? this is going to be a daily driver/weekend warrior so it wont be raced constantly.
Re: (hondaz6lx)
Try 0-100 .
@ OP:
Do a compression and leakdown test and see what the deal is. If they're both good changing the timing belt and let a rip. Good tune and not beat on = long lasting. Don't skimp on tune or it'll fall apart fast.
Try 0-100 .
@ OP:
Re: risky? (slayerfromhell212)
LoL
Find out where it's burning oil from.
Leakdown or compression test will tell you if it's a piston ring. If not it's probably the headgasket.
EDIT:
I'd becareful if the headgasket's leaky. You heat the block up too much (hold it too high too long) ur gonna warp the head.
EDIT:
Re: risky? (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slayerfromhell212 »</TD></TR><TR><TD CLASS="quote">yeah i was asking cuz my friend has a rsx-s and it burns oil so where may i find all these possible leaks?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">LoL
EDIT:
I'd becareful if the headgasket's leaky. You heat the block up too much (hold it too high too long) ur gonna warp the head.</TD></TR></TABLE>
Leak down and compression test will tell you if it's a piston ring. If not it's most likely your headgasket.
EDIT:
mike2343
02-02-2006 03:39 AM
