Which reservoir is for clutch fluid
On the top corner of the drivers side engine bay there are two reservoirs, one larger than the other, which one is the clutch fluid reservoir? And how do I bleed the clutch fluid to replace it?
Re: Which reservoir is for clutch fluid ([VTEC]TL)
The smaller of the two is the clutch fluid reservoir. To bleed it, just pump the clutch and crack the bleeder valve like you would when doing brakes.
