Replacing AC in EM1
Replacing AC in EM1
Picking up an EM1 that has had the AC taken out of it.
What parts are interchangable with the EM1?
Any B-Series compressor work?
Which Coolant lines would I need?
Will a Condensor from any Civic work?
Are there any threads on installing AC into a B-series swapped 99-00 civic?
Re: Replacing AC in EM1
There are a lot of parts you're going to have to get, depending on if it has ALL been taken out or not. I mean, you're talking about the whole compressor, condensor (and all brackets, the fan, fan motor and shroud), then ALL the lines and brackets for those, bolts and everything. You might just want to go to majestichonda.com and start looking at the parts catalog. Just be careful what application you insert.
As for part of your question, I think all 96-00 Civics use the same parts in the a/c system.
As far as I've gathered, everything else can come from any 99-00 Civic. Maybe not the line connecting the Compressor?
Can anyone confirm this?
