Replaced Rotors, still shaking
Old 08-11-2003, 11:26 AM
Inigo Montoya's Avatar
Default Replaced Rotors, still shaking
Couple of weeks ago I noticed that I was getting some shaking while braking. So figuring that I has a warped front rotor, I went and got some replacements (lifetime warranty) and installed them. They seemed to improve things, but now it seems I am getting the shaking back.
I have not done and racing, road or autocross, and it has only been a few thousand miles since I did the replacement.
Anyone have any other things I should check at this point. Still have drums on the rear, car has 105,000 miles or so. 98 coupe.
Old 08-11-2003, 11:33 AM
obsidianG35's Avatar
Did you change the pads at the same time?
Old 08-11-2003, 11:56 AM
phoenix1.8's Avatar
check your tires out i had a bulge in teh side wall of mine and it was causing vibration while going over 70 and when i was braking...new tire....all fixed
Old 08-11-2003, 08:02 PM
Default Re: (r4integra)
edit, double post
didn't change the pads at the time of the rotors, i did inspect them and they were smooth (not glazed), no big chips or anything, and plenty of pad left.
It would be the next culprit, i wanted to see if anyone thought it might be something more serious.
Tires look fine on the inside and out, just got new ones under 7,000 miles ago.
Old 08-11-2003, 08:04 PM
eg_nezay's Avatar
Default Re: Replaced Rotors, still shaking (Inigo Montoya)
Have you had your wheels balanced?
ALso check your tie rods, I had a bad tierod before and caused shaking.
Old 08-11-2003, 08:28 PM
drevinder's Avatar
Default Re: (Inigo Montoya)
[QUOTE=Inigo Montoya]didn't change the pads at the time of the rotors, i did inspect them and they were smooth (not glazed), no big chips or anything, and plenty of pad left.=QUOTE]
you should have done the pads ,,,,,,,,, always do the pads when you putting new rotors on no matter if they only been on there a couple hundred miles its a must that you change them,,,,,,,,,,
now i would go out there and get new pads and get your rotors turned so they are smooth again and that might fix the problem right up
Old 08-11-2003, 08:45 PM
tominos's Avatar
Default Re: (drevinder)
im in the same boat as you.
resurfaced my rotors couple months ago, didn't replace pads, now it's shaking again. guess you live and you learn
rgar98
Honda Civic (2006 - 2015)
03-23-2015 03:57 PM
WhOIZiT
10-01-2003 06:56 PM
rscawley
10-14-2002 03:17 PM
Evan55
24
08-08-2002 03:09 PM
Sp00nLude
12-30-2001 05:52 PM
Quick Reply: Replaced Rotors, still shaking
