repinning a z6 distributor to a y8 plug
I put a z6 in my sisters 00 ex after her motor went out, now I just need help repinning the distributor. I need yalls help please.
The y8 distributer wires are as follows, top row from left to right-
pink, pink/blue stripe, blue, white/ green stripe. the bottom from left to right- black, white/blue stripe, white, black yellow.
The z6 wires are one plug-
black/ yellow stripe, blue.
the next plug top row from left to right-
pink, pink/blue stripe, blue, white/ green stripe. bottom row left to right- white, white/ blue stripe, blue/ white stripe, blank no pin in last hole.
Can you please help me repin my z6 distributor to a y8 plug.
Thank you for your help
Kris
Kris
Re: repinning a z6 distributor to a y8 plug
I looked on that page and I couldnt click on the link that would help me. It maybe my computer or me just not to computer savy. Anyone else please I need to get this car running.
you will only use the 8 pin harness form both dizzys. connect wires by location. then connect the blk/ylw wire from the 2 pin harness of the z6 to the blk/ylw wire that should b left on the y8 harness. if u want to connect the blue wire from the 2 pin harness u have to take the dizzy apart and connect the blue wire to open terminal on the side of the ecm. good luck
PrestonCRX
04-07-2006 06:30 PM
