!!! Is this repairable? !!!
Can someone tell me if these mounting holes are repairable without having to use a different block? What you are looking at are two stripped holes where the driver side motor mount connects. I've heard that time-serts may be able to save this block, any opinions??? Any info would help - thanx
BTW, that chip doesn't go nearly as far as it looks, not even a quarter of an inch.
Re: !!! Is this repairable? !!! (Captain Hammerite)
yah you could also drill the holes out and retap them and use bigger bolts but you might have to drill the holes in the mount out too so the larger bolt fits threw me. it may be easier to use the heli coil method as stated above(i'd just use heli coils)
its definitly fixable, but drilling out that block wont be easy, be prepared for the drill you spin on you bc i guarantee it will catch.
just drill it out and re-tap the hole , and use the next size bolt.
done.
~~~next post
done.
~~~next post
1 Post
Re: (92BlackSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92BlackSi »</TD></TR><TR><TD CLASS="quote">Could weld some new metal there also and retap the threads. Any decent machine shop will own that.</TD></TR></TABLE>
Agree. Give it to profesionals. And they do like that.
cmamtower
10-23-2010 08:53 AM
