Removing worn/stripped lug nuts
I've had it with my stupid Kyokugen lug nuts. I've tried removing them in order to install my suspension but it was too hard. The heptagonal key got stripped and worn down too. Some of my lugs are so worn I don't think any tool could fit into it and get them off. They're just put in too tightly to be removed by hand. Does anyone know a good shop in the socal area that could remove stripped/worn down heptagonal lug nuts? I don't care about the cost/labor fee I just want to get those pieces of **** off right now!
Re: Removing worn/stripped lug nuts (sshaikh01)
im not from your area but any good tire shop should be able to do it no prob...
get some Zenki's next
http://www.heeltoeauto.com/mar...x.htm
Marcus is a board member/sponsor
-Bryan-
-Bryan-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sshaikh01 »</TD></TR><TR><TD CLASS="quote">are you refering to the studs ?
they have to be pressed out and pressed in by a machine shop.</TD></TR></TABLE>
No I don't have studs on them right now, just the open-end lugs
Help!
Help!
Re: Removing worn/stripped lug nuts (THEINTEGRATION)
The old sacrificial socket trick. If you have craftsmen or any other warrantied tool set use a socket that is one side too small and hammer it on then put the ratchet or breaker bar on and yank it off.
Re: Removing worn/stripped lug nuts (KOALA YUMMIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES »</TD></TR><TR><TD CLASS="quote">The old sacrificial socket trick. If you have craftsmen or any other warrantied tool set use a socket that is one side too small and hammer it on then put the ratchet or breaker bar on and yank it off. </TD></TR></TABLE>
Tried that, the lugs only got more messed up...
I had the kyokugen lug nuts too. That piece of **** key pissed me off. Started messing up the lug nuts too. I had to order a new key. Was like $20, but after this, I'm just getting a new set of lug nuts.
Oh yeah, and I also had to hammer in a socket and jack up the lug nuts some to get them off. Was my temporary fix, good thing i had some extra kyokugen lug nuts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEINTEGRATION »</TD></TR><TR><TD CLASS="quote">
Tried that, the lugs only got more messed up...</TD></TR></TABLE>
Then you failed. Give up now.
Same thing happened to me ... I almost gave up until I saw this at Target
:drum roll:
http://gator-grip.com/
:drum roll:
Re: Removing worn/stripped lug nuts (maztur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maztur »</TD></TR><TR><TD CLASS="quote">Same thing happened to me ... I almost gave up until I saw this at Target
:drum roll:
Man, I've been looking for those!
:drum roll:
tamadrumr88
07-14-2008 12:25 PM
tamadrumr88
Northeast
07-14-2008 10:24 AM
