Removing TB
Removing TB
Car: 98 dx w/ Y7
Is it ok to remove the throttle body without pulling off the coolant lines?
Or will coolant pour all over once the tb is lifted off?
I need to replace the MAP sensor and I cant get enough pressure on the screws to remove em because it is on the back of the tb. So the screws are getting messed up.
TIA
TIA
Re: Removing TB (Malakai)
yeah it is ok to remove the tb without removing the coolant line or iacv. and and u mean the kit thats attached to the lower of the tb ,right ?..the worse case is .some coolant will be slightly flows out..only a tiny bit..so u are fine. dont worry. just make sure u might need to get a new tb gasket and maybe new o ring for map sensor.
Re: Removing TB (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote"> and u mean the kit thats attached to the lower of the tb ,right ?..</TD></TR></TABLE>
what kit do you speak of? I just assumed it attached like a b series tb to the IM?
Am i wrong in thinking this?
If some or no coolant comes out then I'm fine with it. I hope that i dont tear the tb gasket, and im hoping the o-ring will be reusable.
no.thats iacv attached to intake manifold .the one i talked about is the one device thats attached right under TB, or maybe u dont have one in your system. and even if u dont tear up the gasket, u might as well replace it anyway .cause it is to seal from vacume leak. and to replace the map sensor..u dont really have to take out TB
i know, but i dont have a way to get the screws loose. I tried and the phillips head screws are getting messed up cause i cant get enough force on them. So my next option is to take it off.
polything
23
07-27-2012 08:23 AM
BlueShadow
08-07-2004 11:28 PM
