Removing EK rear seat...quick question HELP!!
i have searched and have found no write ups on how to remove the rear seats in an ek hatch. do you have to undo the bolts on the back of the seats. i have hear that there are clips that you have to remove but i dont see any on my seats. the only way that i can see doing it is removing 2 bolts on the back of the seat on each side but i figure there is an easier way. if anyone knows please help. pics would be appreciated also. thanks alot
Re: Removing EK rear seat...quick question HELP!! (tyflip2)
yeah on the back side of the seat fold them down and take out the bolts on each section of the seats and then slide the backs out of the hinge. Hope this helps.
Re: Removing EK rear seat...quick question HELP!! (haccord2.2)
will the bracket that the bolts are in just be dangling in place or will they come off with the seat. i understand what your saying but just need a little more clarification
un bolt the seat from the 4 10mm bolts on the sides then there is another that hols the brackets onto the thier mounts on the car which is another 10mm bolt
just take it apart and you will understand
Re: (ITRacer121)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRacer121 »</TD></TR><TR><TD CLASS="quote">un bolt the seat from the 4 10mm bolts on the sides then there is another that hols the brackets onto the thier mounts on the car which is another 10mm bolt
just take it apart and you will understand </TD></TR></TABLE>
yeah pretty much what he said after you get the back of the seat off, then there is one bolt that holds the bottom of the seat down in the back, and two clip like things that just pull out with the seat, they just hold down the front of the seat and keep it form moving around they just sit in the holes. Then the hinges for the seat backs are attached to the car with on bolt for each side, and the middle two hinges are connected together by one bolt going through the this metal bracket that is welded to the car. If you don't understand then just let me know, I will look on my computer and see if I might have any pictures of what I am saying.
FSUseminoleEM1
12-17-2009 10:21 AM
wushubrian
02-24-2005 08:57 PM
