removing crank pulley from b series
How would i go about doing this? its incredibly tight, i have tried using a breaker bar but i was unable to break it loose.
Any ideas guys?
Any ideas guys?
Ingersoll-Rand 2135Ti.
http://www.amazon.com/Ingersol...SRM7E
Best $250 you'll spend on an impact wrench. Combine this with an 80-gallon two-stage oil drive air compressor at 135psi, you'll be singing all the way home whenever it comes to any bolt or nut on your honda.
Re: (vtecftw)
if you have a friend with an impact wrench and a decent sized compressor, I say go for it. but if you don't, then spending the money for a setup like that is kind of overkill. good luck either way.
.cingham
39
04-11-2004 12:05 AM
