removed sticker... but also removed paint =/ help
Old 03-21-2005, 11:44 PM
idriveadelsol7's Avatar
Default removed sticker... but also removed paint =/ help
i tried all that goo gone, goof of,f wd40, adhesive remover and nothing worked. that mortal kombat (scorpion) sticker has been on the car for like 10 years (1994 no joke). i finally bought me some decal stripper/paint stripper also. now, why did the paint come off before the sticker? gee. i got a rectangle spot on my car 4 inches long 2 inches thick. white paint is gone and you can see the primer clearly. is this fixable without getting the entire piece (trunk lid where the keyhole is) painted? i'm not looking for perfection, just nothing not to noticable. thanks... i cut my nails, o my god my fingers hurt.
Old 03-21-2005, 11:47 PM
Unceasing Measure
Archidictus's Avatar
Default Re: removed sticker... but also removed paint =/ help (unrefined7)
You can do it right or you can do it cheap. The right way would be having a shop match the current color of your car to a chip and spray your entire boot lid that color.
The cheap way is to spot-repair it and hope for the best. Wet sand gently .
Old 03-21-2005, 11:48 PM
sprinthart's Avatar
you will need to repaint...sorry, unless of course you want to use 'touch up' paint from the dealership.
HalfAnP's Avatar
Location: I put on my robe and wizard hat, NY...err Bay Area--->Texas
I'd say you could try and get some touch up paint (in the spray can at autozone or something, but that probably wouldn't work out too well. I think you're probably stuck going to a body shop to have it touched up professionally. It shouldn't be all that expensive judging by the size of the spot.
Think about it, you took what was left of your clearcoat, paint, the sticker and its adhesive all the way down to the primer, I dont think you'll be able to fix that with stuff from autozone unless you've had experience with bodywork in the past.
Old 03-22-2005, 12:09 AM
i''ve worked with alot of ghetto **** and it came out pretty alright for what i paided for. but any way... how much would it cost to touch up at an autobody? to bad i don't have a digicam.
Old 03-22-2005, 12:24 AM
sprinthart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unrefined7 &raquo;</TD></TR><TR><TD CLASS="quote">i''ve worked with alot of ghetto **** and it came out pretty alright for what i paided for. but any way... how much would it cost to touch up at an autobody? to bad i don't have a digicam.</TD></TR></TABLE>
take your car to a several body shops and findout. that would be your most accurate way to findout the cost.
Old 03-22-2005, 01:40 AM
civiccoupe94's Avatar
no... the cheapest way is to get a bigger sticker that says DOHC VTEC or HONDA POWER... its going to cover that spot and get you at least 5 horsepower!!!
Old 03-22-2005, 05:36 AM
khmboostedeh2's Avatar
Default Re: (civiccoupe94)
It'll prolly cost like 50 buck. As an alternative, I'd just tape off the area that you messed up, get a color matching paint in a spray can, spray it twice, wetsand with 1500+ grit sandpaper, spray again, and then clear coat, and wet sand again. spray light coats and let them dry completely.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">no... the cheapest way is to get a bigger sticker that says DOHC VTEC or HONDA POWER... its going to cover that spot and get you at least 5 horsepower!!!</TD></TR></TABLE>
only 12 posts on honda-tech you are already proving yourself useless.
GoLowDrew
Paint and Body
06-23-2013 10:22 AM
Herbyy
Paint and Body
29
08-23-2010 02:34 PM
SIR EF9
07-08-2008 09:25 PM
JDMITR22
01-05-2004 06:41 PM
JCiv03
05-21-2003 07:09 AM
Quick Reply: removed sticker... but also removed paint =/ help
