remove exhaust to install short shifter?
I was searching on how to install a short shifter on a 99ex and even though I didn't find anything on my actual car, I found that some people said about dropping the B Pipe and some said nothing. Is it necessary to unbolt the B Pipe or can it be done easily without?
Re: remove exhaust to install short shifter? (civic_speed99)
You "can" do it with the B pipe still on, but it's a bastard. Just unbolt it from the catalytic converter and be done with it.
Re: remove exhaust to install short shifter? (Ricey McRicerton)
Yeah either unbolt the mid pipe from the cat or the cat from the header, take it off it's hangers and let it drop down. Plenty of room now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">You "can" do it with the B pipe still on, but it's a bastard. Just unbolt it from the catalytic converter and be done with it. </TD></TR></TABLE>
Yup unbolt it from the cat, unplug the o2 and disconnect the hangers. Also check to see if you need to bend the weight up on the end of the linkage and cut the heat shield off the pipe as well. Before I had purchased a aftermarket exhaust I had to remove the shield and bent the linkage because the shifter would rub and vibrate at idle.
Dont take the exhaust off i have an 99 ex and i thought i had to but i just pushed the pipe over enough to slide the shifter assembly out. When i did it it took maybe 25 min to install it without the piping coming off... you will need a swivel socket head(dono if thats the exact term) to get the 2 bolts that are rite above the pipe
easiest way
easiest way
Re: (ImportRacr05)
ive gotta thermal cat back on my 92. i dropped the b pipe to get the shifter in. it just makes it easier, and its much less tome consuming..
remember. work smarter not harder
You guys are like 50-50 both ways. I'll guess i'll make the decision when I get under there. Is this something that can be done on jack stands or should I use a lift?
Re: (civic_speed99)
I just put the skunk 2 dual bend on last night, I have greddy evo exaust and I simply undo the two rear 12mm bolts then the trans. shift stabilizer bolt(the one w/ the bushing mounted to the trans.) drop that bar and the shifter , and install the new shifter put some high temp grease in there. attach the three bolts and your good to go, took me maybe 25 min. total.... good luck hombre'
Re: (civic_speed99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_speed99 »</TD></TR><TR><TD CLASS="quote">Did you put your car on a lift or jackstands?</TD></TR></TABLE>
lol if you want to install the short shifter you better put it on a jackstands at least.
Re: (civic_speed99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_speed99 »</TD></TR><TR><TD CLASS="quote">You know what I meant. Is it hard to do on jackstands, or should I find a place with a lift.</TD></TR></TABLE>
I know I'm just pulling your chain
BTW yeah using a floor jack with jackstands will be fine. Just make sure you jack it up far enough so you can enough room.
warchieft2k
11-24-2006 09:02 PM
