Reman Caliper questions
Old 10-17-2005, 10:17 AM
DC4_MADMAN's Avatar
Default Reman Caliper questions
I am looking for rear teg calipers for my drum->disc swap and have a few questions.
1) What are the best remans? Bendix? Cardone? Beck/Arnley?
Fastbrakes also sells remans, are these any good?
2) What are the the differences of- unloaded, semi-loaded, and loaded calipers?
Thanks.
Old 10-17-2005, 10:25 AM
Mr. Badwrench
boostedcivicsir's Avatar
Default Re: Reman Caliper questions (4door_demon)
a1 cardone is good, i have had luck with them in the past. bendix has always had a good name in brakes.
un loaded - just the caliper
semi-loaded - caliper and mounting bracket
loaded - caliper, bracket, and pads.
Old 10-17-2005, 10:28 AM
DC4_MADMAN's Avatar
Default Re: Reman Caliper questions (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">1) What are the best remans? Bendix? Cardone? Beck/Arnley?
Thanks, so the best bet would be to get semi-loaded, since I need everything but the pads.
Old 10-17-2005, 10:44 AM
Mr. Badwrench
assuming thats what they mean, i mean thats what i would take it as. but if you dont needs pads, i believe the semi loaded would be the way to go.
Old 10-18-2005, 01:22 PM
DC4_MADMAN's Avatar
What I decided to do was buy cardone unloaded calipers, cardone brackets and use OEM hardware(pins, bolts, boots, etc) to put the 2 together. Seems this was the cheapest route.
I was going to rebuild the calipers I have from scratch using OEM hardware, but they are rusted to **** and beyond.
Flexin5
03-27-2006 11:29 AM
pikyone
Acura TL, RL & ZDX
10-10-2005 04:21 AM
dayaftertomorrow
Acura TL, RL & ZDX
11
05-29-2005 10:15 PM
Understeer
12-15-2003 10:26 PM
Quick Reply: Reman Caliper questions
