Reinstalling a/c system in 99 Civic DX -will B-series compressor, condensor, etc fit?
I have a 99 Civic DX coupe that a moron took off the a/c. I am going to put it back on but have no a/c condensor, condensor fan, a/c hose manifold from compressor, nor a compressor. What condensor do I need? They have 4 different types and how do I know which one? I have figured out that I am supposed to have a Nippendenso a/c compressor.
My main question is will a B-series compressor, condensor, etc fit on this (I guess) D-series engine? All I know is that it is a 1.6 non-VTEC.
Re: Reinstalling a/c system in 99 Civic DX -will B-series compressor, condensor, etc
if you use a b series compressor, you'll have to use si lines that go into the compressor.
Your going to need the compressor, dryer, both high and low side lines from the firewall on passenger side to the compressor. Also need the condensor with fan and make sure whatever you do replace all of the O-rings while doing the install. As stated above if you go with B series parts then you'll need those lines.
I've already got the accumulator and the o-rings are a given.
Ehron
01-04-2003 05:13 AM
