rebuilding a old d16z6.
Guys, is it true that rebuilding a old motor even though it has been redone totally like the base with an oversize and new piston and the head resurfaced and new seals that it would have to much compression and would end up burning some oil?
I do want to know that because i got for free a d16z6 (1993)with about 175 000 miles on it. Is it worth it to rebuild? I just want to install a vtec engine in my civic 4 door 2000. I do not plan to go race or do drag. Just a daily car, family car....
thanks
Marc-André
Modified by marcus029 at 10:11 AM 9/6/2007
thanks
Marc-André
Re: rebuilding a old d16z6. (marcus029)
you shouldn't have any problems if you take it all apart replace all the seals have the block and the head spec and reworked where needed. Assemble it with good parts ect. Expect to spend a little cash to get all the work done.
Re: (marcus029)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marcus029 »</TD></TR><TR><TD CLASS="quote">like below 600-700 dollars total?</TD></TR></TABLE>
Depending on the condition of all the key components I would imagine that is a good estimate with stock parts. A block tank and hone usually runs about 85-100 or so. Stock seals, rings, bearings etc... should be about right. I would tear it apart and call some shops for quotes.
When i will put it into my 2000 civic would i need to have the whole wirering from the d16z6 engine or do i use the one i have right now with my d16y7? I know i need a obd2 to a obd1 conversion connection, but do i also need to change my computer?
Is it a p28 right?
thanks
Marc-André
Is it a p28 right?
thanks
Marc-André
ci_v_ic
08-10-2006 06:24 PM
93jdmEG
05-30-2005 09:24 AM
