Rear Wheel Bearing Replacement .....?DIY?
All the threads that looked liked they would help didn't have the pictures up anymore. Its a 96 cx so I have rear drums. My question is how do I get the rear drum cover off and also how do I get the hub assembly out? Pictures would be great!!! Thanks.
Dan
Re: Rear Wheel Bearing Replacement .....?DIY? (VTcivicHB)
To get the rear drum cover off, find some bolts that are the right size and thread pitch and screw them into the holes on the cover and it should come right off. Oh yeah, make sure you have your e-brake off!! LOL.
To get the hub assembly out you simply loosen the spindle nut and the whole assembly should come off. That is as far as you have to go, because the new bearing comes as an assembly as well with the lug studs and everything. Its really simple!! Good Luck!
