rear main seal
rear main seal
im replacing a rear main seal on my gsr and was wonderin if i got more then one gaskets that need to be replace cuz in the box i got from the auto store came with like 4 different gaskets one rubber one and 3 paper like ones.... i know the round rubber one fits but the other paper ones look like they wont fit anywhere..?? and on the round gasket should i put silicone around it to insure it wont leak again??
Re: rear main seal (GSR_hatch936)
You sure you got the right set?
You don't have to seal it, just clean every thing good, lube the inside if the seal with oil (the outside doesn't need any lube), and install. Just make sure you get it in there straight and don't scratch the crank.
Re: rear main seal (stock_honda_coupe)
ok after the flywheel is there anyother bolts that i need to take off??? that wat i need to know?!
thats wat i thougth so there's just one gasket to be replaced right?? i dont need the others?
Take the flywheel off pop the old seal out lube the new one and press the new one in, you can use a piece of pvc pipe and tap the new seal in place nice and even. You can use some some of the gasket tack stuff around the outer lip of the seal were it mates with the case but thats not really nescissary. ejoner
if your sure just the rear main is leaking then just tap in the new seal if its the cover that holds the rear main seal in, then you have to drop the oil pan and take the cover off and use silicone or the gasket they gave you......
Re: rear main seal (JDMbiAtcH)
i pretty sure its the rear main seal.... cuz i replaced all the gaskets i could out side the car like valve cover and oil pan.... so the i just figured it would be the rear man seal.. cuz it was still leaking oil and i used silicone around both vavle cover and oil pan gaskets!! i dont wanna have to drop the tranny again if it keeps leaking... where else is there gaskets that would need to be replaced while the tranny is off????
Modified by GSR_hatch936 at 10:42 AM 11/2/2007
Axle seals if you like, it's easier with the tranny out.
I hope you didn't put sealer on the whole oil pan gasket, just in the 4 corners by the crank.
Re: (1992Si)
dont member if i did but i know i did around the cranks.... but thats not wat im worried bout... i know a guy that works on honda-acuras, and he say's he never torques the flywheel bolts or the clutch bolts... and i dont know wat size i need for my clutch aliner or watever its called.... ill post pick...
BauleyCivic
35
04-29-2004 02:30 PM
