Which rear LCA should I get???
I don't know what's good out there for Rear Lower Control Arms, so please give me some feed back on what you think I should go with. I have a 98 hatch.
-Do any of them come with rubber bushings?? |
Re: Which rear LCA should I get??? (civichbcx)
I would suggest either Megan lower control arms. Or, you can go OEM and get GSR lower control arms.
bump!
Do a search.. BTW i heard the Megans bushings barely last a month
Im runnin K sports personally |
Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">Do a search.. BTW i heard the Megans bushings barely last a month
Im runnin K sports personally</TD></TR></TABLE> I also heard that they will not mount right sometimes. I will be using Omni. |
Re: (ralphie14)
Re: (-Gambit-)
Does anyone know where to pick up some SRR LCA's?
do the ksports have the hole for the rear sway bar? how much is a pair?
i am running megan racing lca's and i personally love them, bushings are still good, fit great, and sway bar mounts correctly as well, i might have gotten a good set, or there is just alot of trash being talked about them because their a relatively new brand who knows.
Re: (eg2wes)
i got some omni's power lca's on my 96 ek i have had no problems with them here they are on my ek https://i12.photobucket.com/albums/a...yrearchris.jpg and they do come with the rubber bushings
Re: (lazybrown187)
I have K Sports on my 96 coupe, they do have mounting holes for the sway bar and run about 199.99 a pair. I had them for a year now and have not had a problem. I dont know about Omni's lately there have been numerous threads about their Omni parts breaking and them having crappy customer service.
Re: (96CivicBoostCoupe)
I'm using the SRR lca's https://honda-tech.com/forums/images/smilies/emthup.gif . FYI they come with polyurethane bushings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by makavelli1227 »</TD></TR><TR><TD CLASS="quote">Does anyone know where to pick up some SRR LCA's?</TD></TR></TABLE> http://WWW.PERPETUALCONCEPTS.COM https://honda-tech.com/forums/images/smilies/emthup.gif |
Im running SRR one's aswell, very nice indeed
I ran srr on my hatch. It was great. https://honda-tech.com/forums/images/smilies/emthup.gif
OEM ITR LCA'S work quite well. Very useful if you want to maintain a low profile..
i run SAGE RACING on my coupe, they are great! and dont have any lame stars or anything on them https://honda-tech.com/forums/images...s/emsmilep.gif
Re: Which rear LCA should I get??? (E.Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E.Honda »</TD></TR><TR><TD CLASS="quote">These are what I use.......
http://www.adrianteo.com/ebay/eklca/eklca-Images/1.jpg</TD></TR></TABLE> never seen these ones before ...who makes them ....BTW i use the omni lca https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: Which rear LCA should I get??? (underb00steg6)
those are function7's, holy shiet those are pricey though i htink they cost like 250 or more a pair, but they can pretty much withstand a mine field. https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Which rear LCA should I get??? (super_nguyen)
does anyone know which LCA's have polyurethane bushings and which ones are just crappy vulcanized rubber? also which ones have easy ones to replace that don't cost the price of the LCA itself?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super_nguyen »</TD></TR><TR><TD CLASS="quote">does anyone know which LCA's have polyurethane bushings and which ones are just crappy vulcanized rubber? also which ones have easy ones to replace that don't cost the price of the LCA itself?</TD></TR></TABLE> Mine have polyurethane. Function 7 uses polyurethane made by energy suspension at their specs. They are great arms all the way around. Also have the sway bar holes. They also make a nice kit to install the sway bar. Very polite and easy to deal with. Great customer service. E.Honda |
whats so great about aftermarket lca's compared to stock? (other than the weight reduction)
Re: Which rear LCA should I get??? (junkyard_turbO)
they allow you to run wider wheels so the inner wheel dosent rub up agenst the conrol arm, sometime can fix slight camber issues, and offer holes for sway bar endlinks to mount up where there aren't any on dx/lx control arms, and quality ones have polyurthane bushings
function7 !!! expensive, but nice as well as functional...
