Rear LCA Shock Bolt
Rear LCA Shock Bolt
I have a 1995 Civic Coupe and am gonna be puttin on my new KYB AGX shocks and H&R stage 2 springs. I have heard that chances are the rear LCA bolt that mounts the lower shock will snap off most likely when i go to take out the bolt. What are the best ways to prevent this from happening? and anyone have any idea how much new LCA's cost if the bolt gets stuck and i cant drill it or pound it out???
any tips would be appreciated. thanks
Re: Rear LCA Shock Bolt (95CoupinIt)
I got lucky on my car and didn't have the problem. But I would recomend of course gobs of wd-40 or the equivelent. Some people say heat it with a torch.
On my buddies car we broke the nut on the shock itself and got that nut off and pounded the sucker through with a BFH. we had to take the whole lca to do it though, wasn't stable enough while still connected to the car.
Re: Rear LCA Shock Bolt (mps9506)
so you just snapped the welds on the nut thats on the OEM Shock? hmm...sounds like an idea i guess if it gets seized up...hopefully ill be lucky..if not...the junkyard is where i am headed lol
any other suggestions from my fellow HT members is appreciated
Re: Rear LCA Shock Bolt (SuperDragII)
Yea i had that problem too. Had to drill out both sides. When the LCA is off the car it is a lot easier, will be very time consuming. Unfortunatly i wasn't able to get one of the LCA's off the car because of another rusted bolt , so i had to drill it out on the car (took like 4 hours).... not fun at all.
good luck.
[Modified by bigmike, 8:38 PM 3/21/2002]
good luck.
1 Post
I JUST did this, so lemme give you some advice....
Use a Torch and heat the bushing...itll melt the rubber and the metal part will stil be rusted onto the Bolt. Then, start backing it out until the tip thread is out, then use a sawz-all and cut the ******* bolt off...
I wasted 4 hours until I devised this method...works great, especially if your changing out the LCA's for GSR or ITR.
Suprdave
Suprdave
Re: Rear LCA Shock Bolt (Suprdave)
drill it out.
cut off the ***** tip of the bolt with a dremel or grinding wheel.
drill into the bolt end with a 1/4" drillbit.
see if you can unscrew the bolt (dont snap the head off)
if you cant turn it yet, increase the drill size.
all you have to do is drill as deep as the threads and shock part are thick.
make that bolt into a tube to relieve some stresses and it heats the bushing's sleeve too.
good luck bro.
if that does not work. drill both ends and drop the LCA out.
good luck bro.
Re: Rear LCA Shock Bolt (owen_the_soyboy)
USE AIRTOOLS AND YOU WILL NOT HAVE A PROBLEM!! ive lowered on civic using hand tools, broke all the bolts i could, next two cars i used air tools and did not break a single bolt..
Re: Rear LCA Shock Bolt (95CivicEX)
[Modified by mantic6t9, 5:09 AM 3/22/2002]
Re: Rear LCA Shock Bolt (mantic6t9)
Well, i've never encountered a problem like this. I've only seen the welded on nut on the shock break one time. Also, i'm from down south, where we don't have snow, hence, our cars do not drag through salt. Also, i almost always use air-tools. The Air Compressor is the gift that keeps on giving.
Man.,
I had the same fu**ing problem! On my brother-in-law's 94 Gs-R, we installed KYB AGX & GC Coilovers all around, and the damn lower bolt on the strut was rusted on, we tried everything...hand tools, breaker bar, liquid wrench, at the end, we went to the dealer and bought (2) new LCA's for 62.22 each, and cut the lower-half of the strut off...man was that a pain, took at least 6hrs...man soak that **** with liquid wrench or wd40 the day and night before! or else ur sure as hell gonna be cursing!
good luck.
vnt
good luck.
vnt
94CivicSi
03-24-2002 05:21 PM
