rear hub to disc conversion ( have a del sol and the civic)
what exactly do i need to take off of the del sol for the complete disc conversion i have the del sol sitting there and i need to know what i want or have to pick from it to do this conversion from hub to disc... i may take the front spindles also.. https://honda-tech.com/forums/images/smilies/emthup.gif
(5th rear disc topic Ive seen this week)
its a hell of a lot easier to just use the entire trailing arm |
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">(5th rear disc topic Ive seen this week)
its a hell of a lot easier to just use the entire trailing arm</TD></TR></TABLE> thats what im doing https://honda-tech.com/forums/images...es/emsmile.gif starting the conversion here in about 2 hours https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: rear hub to disc conversion (pane93civhb)
I thought that we were supposed to search first. There is another thread right below this one right now too. https://honda-tech.com/forums/images/smilies/emsad.gif
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">its a hell of a lot easier to just use the entire trailing arm</TD></TR></TABLE> https://honda-tech.com/forums/images/smilies/emthup.gif If you must, you can take everything off of the trailing arm except the actual trailing arm and swap it, but that would be even a BIGGER pain in the butt than actually taking it all of as one unit. And don't forget to heat/WD-40 the bolts. https://honda-tech.com/forums/images/smilies/emthup.gif -Shane |
