Rear drum to disc conversion on a '96 Civic EX
What master cylinder and brake booster do i need to get for this conversion. I have already done the swap to 99 si rear discs but since my MC is for disc/drum my pedals feel mushy....CAN ANYONE PLEASE HELP?!
Re: Rear drum to disc conversion on a '96 Civic EX (AutoxEK9)
a 4040 prop balve should fix that and maybe the si booster and master cylander
but the prop valve is a must if you've eliminated abs
Re: Rear drum to disc conversion on a '96 Civic EX (integra6650)
I have never ahd ABS on my car so is the proportioning valve still an issue?
the ex mc/booster is the same as the 99/00si mc/booster. I checked part numbers when I did the rear disc conversion on my 98ex...
Make sure that you have the 99-00SI prop valve and bleed your brakes.
Re: Rear drum to disc conversion on a '96 Civic EX (kommon_sense)
thanx so i just need the 4040 prop valve from a 99si and i should be good right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoxEK9 »</TD></TR><TR><TD CLASS="quote">thanx so i just need the 4040 prop valve from a 99si and i should be good right?
Yes. Also, did you bleed the brakes?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoxEK9 »</TD></TR><TR><TD CLASS="quote">thanx so i just need the 4040 prop valve from a 99si and i should be good right?</TD></TR></TABLE>
correct.
correct.
thanks guys the prop valve is on order and should be on my car in a few days....no spirited driving for now...
AThiker
22
02-27-2005 05:14 PM
vadersi
02-10-2005 07:18 PM
