What sensors are a MUST?
Old 05-09-2010, 07:39 AM
Slosc2's Avatar
Default What sensors are a MUST?
D16z6, never runs through emissions and doesnt see much time on the road. Looking to eliminate a lot of underhood wiring at the same time I tuck and shave the engine bay. What sensors on the engine are absolutely needed in order for the car to run and idle correctly at all times?
Old 05-09-2010, 07:49 AM
EJeff8's Avatar
Default Re: What sensors are a MUST?
...What?
Old 05-09-2010, 08:05 AM
forcefedferio's Avatar
Ummmmm....all of them, except for the evap purge solenoid on the back of the I/M that will not cause it to run differently or throw a CEL.
Old 05-09-2010, 08:17 AM
gibsanez's Avatar
Well, I had my H22 on eCtune, and the only sensors left on the engine were for VTEC, oil pressure and water temp really. I had no IAB's, no O2, IACV, FITV, etc.
Old 05-09-2010, 10:33 AM
Slosc2's Avatar
I don't care about a CEL.
And it ran correctly?
I figure all the wiring needed for it to run correctly would be:
Distributor
Alternator
Fuel Injectors
MAP
TPS
Any other helpful input?
Old 05-09-2010, 10:38 AM
bgdriver's Avatar
LOL ecu grounds and IAT would be nice. VSS and reverse lights are pretty dandy too. oil pressure light, coolant temp and fans help out too. IAC if it neeeds to start in the cold
thewrai6th
05-24-2016 03:15 PM
Vague
10-08-2015 01:56 PM
onesikgsr
02-06-2008 07:22 AM
BlackoutVTi
15
09-14-2007 08:47 PM
RippSpeed
05-05-2007 07:11 PM
Quick Reply: What sensors are a MUST?
