Rear Disc swap? EK
Rear Disc swap? EK
Just put my '94 Del Sol VTEC Rear Disc swap into my '97 Civic CX. The Del Sol ebrake cables won't work. I'm planning on using 99-00 Si cable, any suggestions? Also I took the '94 Del Sol VTEC Prop. Valve, will this work well for my application? Should I upgrade to an Si/EX Brake Master Cylinder, Booster? Thanks for any help.
Re: Rear Disc swap? EK (Spoon1)
I'm wondering if the Del Sol one will work eventhough it's a different design and won't mount straight up to the chassis, all the brake lines will still connect to the valve itself and a little mounting bracket could be made very easily to bolt the valve to the chassis. What do you think?
Re: Rear Disc swap? EK (brokstar)
I've got the same set up on my DX coupe but I only had to buy the 99-00 Si E-brake cables for $80. Didn't swap out the Prop valve or booster either and I still get a full lock up in the front brakes before the rears do.
==> http://home.mpinet.net/t-hero/DiscBrakes!!.htm
Propulsion
03-24-2002 04:09 PM
