Rear disc swap conversion questions...
As long as I dont have to take out any more Metal Gears
I was trying to do a rear disc swap, and the first thing i did was try to unbolt the fitting on the brakeline where the metal line meets the rubber one. That thing is tough as hell and I still havent gotten it out because I'm afraid of stripping it. i believe I used a 10mm open wrench to try to turn it but i can't. Is there a special tool needed, or do i need to bleed the entire brake system to get it loose? Hopefully someone who has done this can tell me, thanks... Jay
Re: Rear disc swap conversion questions... (civicVX)
whats so special about it? If i ask the sears guy, will he know what I am talking about if i ask him to get me a "line wrench"?, is that what u call it? thanks for the info by the way...Jay
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicVX »</TD></TR><TR><TD CLASS="quote">go to sears and buy a 10mm line wrench.</TD></TR></TABLE>
do you mean 10mm comination wrench?
Re: Rear disc swap conversion questions... (JUN EK9)
No he means a line wrench...
a combination wrech is open on one end and closed on the other...
I line wrech looks KIND OF like a closed end wrech but with JUST enough cut out to fit it over the brake lines.... it's so it grips all 6 sides of the nut surface instead of just 4.
Re: Rear disc swap conversion questions... (NonovUrbizniz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz »</TD></TR><TR><TD CLASS="quote">No he means a line wrench...
I line wrech looks KIND OF like a closed end wrech but with JUST enough cut out to fit it over the brake lines.... it's so it grips all 6 sides of the nut surface instead of just 4.</TD></TR></TABLE>
wow, i didnt know that, thanks! i learned something new.
i didnt know if there was a line wrench, and the only wrench that was linear was a combination wrench, so thats what i thought he was referring to
Re: Rear disc swap conversion questions... (rukawa1one)
Just did a disk conversion, this week on a 92, and the left rear gave me problems, ended up stripping it a little. The fitting was rusted pretty bad so I used some, rust free stuff and then took some vice grips to it. Popped right of then.
Isn't that just a flare nut wrench?
Re: Rear disc swap conversion questions... (ntrinsik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ntrinsik »</TD></TR><TR><TD CLASS="quote">
Isn't that just a flare nut wrench?</TD></TR></TABLE>
That's a synonym...
"line wrench"
http://toolcrib.safewebshop.co....html
"flare nut wrench"
http://www.tooled-up.com/Produ...indow
Same thing... quick search of google would've shown ya...
That's a synonym...
"line wrench"
"flare nut wrench"
CRX 2.0V-T
10-16-2006 12:18 PM
AzntaggeR
08-17-2003 07:50 PM
