rear disc question
rear disc question
aight i already searched and found out the proportion valves r the same for dx and si eks. this might be a stupid question but does it matter if its a dx coupe or hatch? and also can u use integra brake cables or should i just get a si cable?
Re: rear disc question (BigChina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigChina »</TD></TR><TR><TD CLASS="quote">aight i already searched and found out the proportion valves r the same for dx and si eks. this might be a stupid question but does it matter if its a dx coupe or hatch? and also can u use integra brake cables or should i just get a si cable?</TD></TR></TABLE>
the valve doesn't make a difference if it's a dx hatch or dx coupe, they are the same.
as for the e-brake cable, and integra will work fine.
HRD PKR
if your using a 96-00 civic as your car.. si works easiest.. but iam sure dc would work
and as the prop. valve.. dx hatch's have it and si's. not coupes..
I have heard of cases where you can use Integra E-brake cables with some modifying. I would just got out and buy Si E-brake cables though.
As for the proportioning valves I have never heard any differences between DX coupes and hatches. But the part number for the two trim levels are the same for sure.
Re: rear disc question (B16B_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe »</TD></TR><TR><TD CLASS="quote">if your using a 96-00 civic as your car.. si works easiest.. but iam sure dc would work
and as the prop. valve.. dx hatch's have it and si's. not coupes.. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by themikewoo »</TD></TR><TR><TD CLASS="quote">I have heard of cases where you can use Integra E-brake cables with some modifying. I would just got out and buy Si E-brake cables though.
As for the proportioning valves I have never heard any differences between DX coupes and hatches. But the part number for the two trim levels are the same for sure.</TD></TR></TABLE>
the brake cables are the same. just installed 00 integra cables on a 98 civic ex.
aight im still kinda confused on the dx coupe and hatch prop valve. im lookin in other threads most of the ppl say to use a hb prop valve. if i have to buy one its not a big deal but if i can use mine, then i dont have to drive to honda
immajackuup
05-29-2008 06:07 PM
