rear disc conversion(portioning valve)
I checked a few places on the internet and can't really find what I'm looking for, but I got my rear drum->disc conversion today and I was told that it would be a really good idea to get a portioning valve, anyone know off what car I should get one?
I heard either 00' Civic Si or any 94-00 Integra GSR, and if you know a good website let me know... thanks
mine is a 95 Civic EX
Re: (pdiggitydogg)
would it be under another name?
I tried slhonda.com and couldn't find anything, so I typed "portioning valve" into the search and got no hits
46210-SR3-962 VALVE ASSY., DUAL PROPORTIONING $133.29 $31.26
Thats crazy high...get a used one... Search the classifieds for someone parting one out or something like that and inquire
Re: (IHateJDM)
ah... PROPORTION... not PORTION thanks
I found this on JCWhitney, but I think it might be over kill for just a modded daily driver:
http://www.jcwhitney.com/autop...0101
Re: rear disc conversion(portioning valve) (raynaud)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">For your generation, you'll want one off the -95 si hatch
Best fit.
hondaautomotiveparts.com
slhonda.com
Dealer...</TD></TR></TABLE>you can use one off a 90- 93 integra (any) or a 94- 01 integra rs. you might also want to upgrade your m/c and booster. you currently have the same as the 95 si hatch.
Best fit.
slhonda.com
i have one off a 93 si. i swapped to disk brakes on my dx hatch but it got stolen before i put the right propotioning vavle in. pm me if you want it ill sell it.
i believe if you replace the master cylinder with one from a 91 ex sedan (4 wheel disc), you don't have to worry about the PP or BB, someone correct me if i'm wrong.
Re: (Iceman05)
here,
check this link out for your master cylinder and brake booster. It'll work because it worked for my 95 DX coupe when I did my rear disc conversion from an EG6.
http://www.hybridautomotive.com/parts/brakes.html Also go on icbmotorsport.com to order the stock proportionin valve for the EG6. Or you can order the 40/40 prop. valve, either one will work fine. I started out with the 30/30 prop valve and it worked fine. But then I swapped it for the 40/40 prop valve and ITR brake booster and master cylinder and it's awsome. Here is the link for the ITR 5 lug conversion but its exactly the same as the EG6 rear conversion. http://www.hybridautomotive.com/tech/5lug/ There is some good info on the proportioning valve, master cylinder and brake booster. Enjoy!!!!
Re: (naya1civic)
dude one website http://www.jdmland.com go to search type in proportioning valve. your done
JDM EJ2
20
10-09-2008 10:00 PM
