Rear disc conversion 95 honda civic dx
Ok. So I'm trying to do a rear disc conversion on a 95 honda civic d's. I'm currently in the process of removing the rear trailing arms from my crashed 94 honda civic ex and have run into an issue with removing the rear trailing arms. There is a line running from the car to the rear disc brake hub which also runs along the rear sway bar to the other hub. I have had people tell me to cut it but I don't know if this is something I will need to transfer from the ex to the d's to make the brakes function properly. I'm on a time limit as my landlord wants the car removed being that it is totalled. I'm in dire need of assistance and would appreciate any help you guys can give me. Thanks
Re: Rear disc conversion 95 honda civic dx
Post pics. I bet the line is for a wheel speed sensor for ABS. Does the EX have ABS? |
Yes the EX does have ABS
And it just snowed so I have to at least wait for it to dry up to send the pics
Originally Posted by Tyreeq86
(Post 51883808)
I will post pics of line tomorrow
Got pics yet? |
These lines I highlighted in yellow are for the wires for the wheel speed sensors that you won’t need if you are swapping these brakes onto a non-ABS chassis. https://cimg8.ibsrv.net/gimg/honda-t...c53f4c4c8.jpeg https://cimg0.ibsrv.net/gimg/honda-t...beb4650a0.jpeg |
So how do I remove or where do I make my cuts?
Get some wire cutters and cut where I’ve circled in red: https://cimg0.ibsrv.net/gimg/honda-t...44a47a3ba.jpeg https://cimg1.ibsrv.net/gimg/honda-t...6127c7ff3.jpeg |
Yes that's the ABS sensor wire, you won't need it.
You will need all the parking brake cables etc. they are different from the drum version. |
Originally Posted by mk378
(Post 51886856)
I can’t believe I didn’t say that... |
