Rear disc brake swap wheel bearing question
I've got a set of rear disc brakes from a 94 Integra with ABS that I will be installing on my 97 CX. I want to go ahead and replace the wheel bearings while I'm at it, my question is what wheel bearings do I need? Does it need to be the wheel bearing for an ABS car even though I will not be using ABS?
Re: Rear disc brake swap wheel bearing question
You need to buy the bearing that match the hub.
I believe ABS cars had bigger wheel bearings. I know they do on the fronts.
Check some place like Delray Acura Parts.com and see if the rears are different.
Here's a start for you. That's 4 door RS, you can do the rest.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
