rear disc brake swap
TSPeed Factory
Re: rear disc brake swap (slowEKsedan)
you'll need 10 mm, 12 mm, 14 mm, 17 mm sockets and wrenches, breaker bar, 10 mm nut flare wrench for the brake lines, needle nose pliers, a medium size hydraulic floor jack.
so basically all you need is basic hand tools.
be sure you to wear eye protective wear so dirt don't fall into your eye while you're under there.
Re: rear disc brake swap (AzntaggeR)
Thanks some one told me I would need a special tool to take the hub off like a phillips tool that you hit with a hammer?
1991EFBeater
05-12-2004 12:05 PM
