rear disc brake pad install problem.
the piece that pushes the pads out is out far. i know its got to be twisted in order to get it in. whats another way of doing this? i tried some wrenches and messed it up alittle. how do u guys get througH?
Electrician
There is a special tool that connects to a 3/8 ratchet. It has a cross one it made for these kinds of vehicles. Pick one up at any local auto store before you **** something else up.
Re: rear disc brake pad install problem. (wizzards581)
If your talking about the piston.... i use a C clamp. You could also use a caliper piston compresor(does the same thing).
edit: I made made a goof my bad
Modified by usdmike at 8:59 PM 8/31/2004
Re: rear disc brake pad install problem. (usdmike)
yea its the piston im talking bout. i dont have other tools besides jus wrenches... i gues ill have to go to local stores.
Electrician
I usually use the piston compressor.
Looks like this:
I use this so I won't have to bleed the brakes if I ever crack open the bleeder screw. C-Clamp works, but you need to crack the bleeder screw. With this tool, it's not needed.
Looks like this:
Re: (Dimi)
Rears gentelmen. It screws in. Just get a long screwdriver and wedge it in there and turn it. It should be pretty aparent which way is going down and which way isnt after a few turns.
Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Rears gentelmen. It screws in. Just get a long screwdriver and wedge it in there and turn it. It should be pretty aparent which way is going down and which way isnt after a few turns. </TD></TR></TABLE>
PLEASE DO NOT TRY TO PUSH THE REARS IN WITH A C-CLAMP.
wickedxbo1
12-30-2001 07:51 PM
