rear disc brake conversion
I am doing a rear disc brake conversion on my '92 Civic HB Cx (yes, I have read the threads/ search already, but I was just curious to hear what everyone has done and if they like it or not). Apparently, you can use either the Civic or Integra control arm. I need to replace the bushings on both of them so I don't care which I use. Thanks
Re: rear disc brake conversion (DailyBlown)
i have done a gsr disks swap for all four conners. i like it https://honda-tech.com/forums/images/smilies/emthup.gif
i have gsr 4 wheel and its great, the back was hard cause of the cable, it was hard to run it but everything bolts right in, just dont use ur abs lines take them out, but straigh from the gsr onto the hatch, with bushing and all............,................hope this helps
I recently have done a full gsr disc brake swap onto my eg hatch.
problem is the parking brake doesnt work. ive tried searching my arse off looking for someone that has posted or done a writeup and no luck. just wanted to know if you were able to fix that problem. thanks in advance. ive tried adjusting the parking brake but there still is no clamp on the rear discs. is there any other way than swapping over to civic si parking brake lines? Modified by phategg at 5:21 PM 8/31/2004 |
Re: rear disc brake conversion (phategg)
I have the rears installed right now. The parking break takes a lot more clicks than I prefer, but it works.
Re: rear disc brake conversion (jolt-tsp)
did you guys use the e-brake line from the integra? or the eg?
Re: rear disc brake conversion (coachkellum)
Teg cables for my 97 coupe - they were short, but nothing zip ties and new mounting locations couldn't handle.
i used the integra cable lines that came with the integra rear disc.
b4 that i had dx drums. can i somehow use the integra cable lines or do i have to swap them out as well? http://images.honda-tech.com/set1//smile/emcrook.gif https://honda-tech.com/forums/images/smilies/emsad.gif |
Unless its a sedan, you can make the integra cables work. I dunno, maybe it'll even work okay with the sedan.
I still have my setup from an SiR but i trying to sell it along with a prop valve. I've done 3 of them, in all instances i was luckily to get complete lines with them i always used EG lines. if you can run eyemount LCAs much beefier then 96-00 LCAs
Re: (snowboarderguy44)
I was attempting to do mine last night, but i cant get this one bolt off. up by the gas tank. i cant get my car high enough. has anyone ran into this problem?
I'm picking up EG Si rear disc's this weekend and doing the swap next week.
Using the EG e-brake cable, prop valve and the rear brake setup |
Re: (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">I was attempting to do mine last night, but i cant get this one bolt off. up by the gas tank. i cant get my car high enough. has anyone ran into this problem?</TD></TR></TABLE>
Which bolt is it, any pics? |
