rear dics coversion trouble-need help
I have a 93 civic hb,and I decided to put rear brakes from an acura on th rear.The swap went fine .Bleeded the brakes got the air out,pedal felt good.Took the car for a drive and there is no brakes.Someone told me that I should of replaced the brake booster with the acura one,is this true.If it is any help I have the front brakes from the acura on the car to.please any help would be great.
Re: rear dics coversion trouble-need help (twerker08)
Re: rear dics coversion trouble-need help (96coupe)
Yes, you should have replaced the booster. Are you still running the stock small 9.5" front discs? You should be able to get the booster from either the teg/ex/si . All should work.
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twerker08 »</TD></TR><TR><TD CLASS="quote">I have a 93 civic hb,and I decided to put rear brakes from an acura on th rear.The swap went fine .Bleeded the brakes got the air out,pedal felt good.Took the car for a drive and there is no brakes.Someone told me that I should of replaced the brake booster with the acura one,is this true.If it is any help I have the front brakes from the acura on the car to.please any help would be great.
brake booster would definately help..and a bit of proper grammer wouldnt hurt either
Re: rear dics coversion trouble-need help (JDM-97CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX »</TD></TR><TR><TD CLASS="quote">
brake booster would definately help..and a bit of proper grammer wouldnt hurt either </TD></TR></TABLE>
proper spelling is just as important as GRAMMAR.
89dxhunchback
37
01-01-2005 12:07 PM
twerker08
11-07-2003 07:01 AM
