Rear brake line fittings.
There was a thread somewhere on here that pertained to the brake line fittings and brake lines used on a 95 EG CX. Either im using the search tool wrong or the thread was removed for some reason. So what i am looking for is the fitting sizes for the rear wheel cylinders (drums) that go into the back of the wheel cylinder. Not the bleeder screw but the fitting that holds the brake line in place. If anyone could point me in the right direction, or has some first hand knowledge it would be greatly appreciated. the lines are original to the car.
Thank you.
Vehicle: 1995 Honda Civic CX
Thank you.
Re: Rear brake line fittings.
Pro search tip:
goto google and start your search terms with "site:honda-tech.com" without the quotes. Follow that with your search terms like EG brake line fittings
This will net you results from this site only that matches up to your search terms.
The search on this site is challenging at best. One member reported it's results are only going back a year. Google does a much better job once you know how to direct it.
brensonkoh
07-21-2013 01:46 PM
JellyBeanMobile
04-04-2006 05:24 PM
Deo
11
12-04-2005 09:09 PM
