rear brake light stay on after swapping 93 si cabin harness into 93 dx coupe
got a dilemma. i swapped over my 93 si hatch cabin harness into my 93 dx coupe. everything plugged up fine except for the cruise control and and some other plugs. now im thinking that some of the plugs are the reason for the rear brake lights to stay on constantly, even after i take the key out of the ignition. only way i can turn them off is by disconnecting the battery terminals.im also running a 01 gsr swap into the coupe.if anyone can help would greatly be appreciated.
Re: rear brake light stay on after swapping 93 si cabin harness into 93 dx coupe
Do the brake lights go out when you hit the brakes? If so, then swap around the two wires on the brake light switch on the pedal.
em1si5853
10-18-2009 08:41 AM
