Rattling noises from engine bay in EG
Anyone had a funny rattling sound (like a loose bolt) coming from their engine bay when revs are kept at roughly 1100 rpms? Don't know why, but rattling comes only at around 1100, and at all other revs its fine. I don't feel a performance decrease in my car, nor does it sound like the engine is gonna explode.
I have an EG with aftermarket exhaust, and im speculating that maybe there's something up with my exhaust pipe as ive scratch it on numerous speed humps before. Any ideas fellas? This rattling sound is really annoying the hell outta me. Thanks |
Re: Rattling noises from engine bay in EG (GummyBeng)
Same here. I am noticing a rattling sound also. Check your torque motor mount (I guess it's called) in the front left lower area. I think my shifter bushings may be out of whack but then again the car could be getting old. Engine is in great condition and I have also hit some bumps...what do you all think.
Peace |
Does it make that rattling noise when you start up the car? If so, then it's the Rod Knock, and your engine is about to blow. I suggest you don't take it on the highway, or else you might get stuck there.
Re: Rattling noises from engine bay in EG (hb_crazee)
is it metalic pinging?
Re: Rattling noises from engine bay in EG (DragIIcivic)
Nope, it ain't a pinging at all. Just a really annoying rattling sound. I doubt my engine is gonna blow up in the next few hours of driving, coz I seldom drive it hard.
But it can be easily heard, at 1100 rpms, and its bothering the crap outta me. Funny thing is, it only occurs at 1100 rpms. As for when i start it up, it sounds all normal. It idles just past 1200 from cold start, but as it fluctuates around 1100, the rattling sound will appear. If you guys have any more ideas, it would be great. I might get under my car tomorrow, and try shaking my exhaust piping to see if it's that. Thanx |
anything touching one of your belts? or loose in general.
heard it from outside the car at all...or just from the cockpit? where does is seem to be coming from....specifically? |
Its coming straight from the engine bay, and can be heard both in da cockpit and from standing outside. Its really hard to tell where its coming from exactly, but i will try to listening to it more closely tomorrow.
If your wondering why tomorrow, its coz im in Australia, and its kinda late to be reving my engine and listening for noises. Neighbors might get upset.
Also, thanx for yur time DragIIcivic..... |
Do you have any type of aftermarket intake stuff and a strut tower brace? I started getting a rattling sound just like you described as soon as I put my tower brace on, and it turns out that a piece of metal on the K&N it tapping against the brace.
http://images.zeroforum.com/smile/h-emblem1.gif |
Check your exhaust manifold heat shield to make sure its not coming loose. Also take a peek at underneath the car at the catalytic converter heat shield and make sure that is also intact. These tend to rattle when they become loose. Also make sure there is no obstruction if your fan is coming on.
Re: Rattling noises from engine bay in EG (KayOs)
Check your exhaust manifold heat shield to make sure its not coming loose. Also take a peek at underneath the car at the catalytic converter heat shield and make sure that is also intact. These tend to rattle when they become loose. Also make sure there is no obstruction if your fan is coming on. |
Re: Rattling noises from engine bay in EG (SpiceyRice)
Ok, since we are on the subject of noises coming from the engine, I thought I would ask about mine. It only happens for about 5 minutes or until my car warms up. It gets louder and faster(tick tick tick tick) as I go faster. It eventually goes away though. It sounds like someone putting a piece of paper on a fan blade(not a car fan, but a fan in general(flap flap flap). Anyone know what this might be?
Okay fellas, i went under the car today and tried to locate the source of the noise. I now believe that the cat may be the source of the rattling noise that i have been describing.
Anyone had any experiences with a noisey cat? Could it be cracked? |
prolly the heat shield around the cat that is rubbing something.
Yep prolly the heat shield, rip it off, see if it goes away cos i had the same problem awhile back. I very much doubt that your CAT will fail, your car is not that old.
same here...i think its cuz i got my polyurethane bushing mounts... http://images.zeroforum.com/smile/emsmilep.gif
[QUOTE]Check your exhaust manifold heat shield to make sure its not coming loose. Also take a peek at underneath the car at the catalytic converter heat shield and make sure that is also intact. These tend to rattle when they become loose.
I also had problems like yours found out it was the heat shield bolt had loosened up just enough to fluctuate at low rpms drove me insane till i found it. http://images.zeroforum.com/smile/mad.gif http://images.zeroforum.com/smile/mad.gif http://images.zeroforum.com/smile/mad.gif |
I got the same thing but it usually only rattles around 70 mph
Originally Posted by 04CIVICEXHOOPTY
(Post 52825698)
