Rapid starter click
Rapid starter click
Hello everyone. I have done a search on HT and on Google and have found contradicting responses so I figured I would post and see what everyone has to say. I have a 94 Del Sol So with a B20VTEC. The car was sitting for a good while but I recently got it running again. To get the car started I had to replace the battery and the starter. Since then, I have had to replace the starter at least 3 other times. More recently, I was not able to start the car using the key on the first try but, could start it jumping the starter from the battery. After that initial start, I could use the key. Today, I went to jump the starter using the battery and the starter made a lot of funny noises (hopefully it didn't **** up anything in the transmission), and the car would not start. I got in the car and tried starting it using the key and all the car did was give me really rapid clicking noises. I was told to make sure it wasn't coming from the dash (starter relay) and I made sure that it was coming from the starter. Any help you guys could give me would be appreciated.
Re: Rapid starter click
Make sure the battery isn't dead. Use a jump pack or jumper cables to confirm.
If the jump start produces the same results, it's not battery related.
If the jump start makes your car turn over or start, your current battery is flat and you need to look into causes of how it drained out so fast, for example is there a short somewhere. Did you check the ECU for engine codes?
Get back with me with the info i requested and we will work from htere.
From what I am seeing, the car is not currently throwing any codes. As far as the battery, I gotta wait for it to stop raining to get it on some jumper cables.
This is normal operation.
If you are unfamiliar with code retrieval on OBD1 civics you should do a lookup, on youtube or google and you can find how. The gist of it is short out the 2 prong plastic connector hanging under the glove box near the passenger door with a paperclip or length of wire and turn ignition to RUN (not start) and watch what the CEL does. It will flash out codes. long flashes are 10, short quick flashes are 1. So LONG-LONG ----- SHORT-SHORT-SHORT is code 23. Write it down and wait for the next code. If there's only one code it will do it over and over with a longer pause in between each sequience. If there are no codes I believe the CEL just stays lit? Someone correct me if im wrong
Aight so I jumped the ecu, no codes. Put the battery to charge with jumper cables on my daily driver for about 15 minutes. Put the battery in the del sol, started right up. Looks like I'm gonna have to try and figure out why the he'll the battery is draining so quick and get a tender for when I let the car sit more than a week.
Yeah stop messing with that stuff. ORder a starter from rockauto.com. You'll spend way less.
And get a battery at menards or some other third party vendor not an autoparts store.
The only upside to the autozone parts is that they are under lifetime warranty. I can't tell you how many times I've gotten a new battery or a new starter this year alone.
right. but seriously save yourself the labor. get on rockauto right now and order a new/reman starter. when it comes, install it, clean up the autozone starter and return it.
crxaddikt
12-05-2007 12:31 PM
