Radio won't work after wire sparked
Here's my scenario. A few days ago i installed an aftermarket stereo on my '93 Honda del sol. I cut the harness from the car and wired it with the ones from the aftermarket stereo. Today i tried to take out the stereo to do some work and it seems like one of the wires shorted out. I tried to run the ground wire directly from any part of the car to the wire of the stereo, and the stereo still would not start. I then installed my old stereo on and that stereo would not start either. I have checked all the fuses and they are all fine. My only question remains is can the wiring harness from the car short out? Or am i still missing something?..
Re: Wiring Harness Problem
Circuit tester (bulb)
I just went to check each one under the hood, did both sides of fuses and all of them lit up. Im real stuck at this point and have no music to my ears :/
Re: Radio won't work after wire sparked
The radio gets voltage on three wires. Two are needed for the radio to work -- constant power from hood fuse box and power from the ignition switch through the dash fuse box. Use your test light to check whether those two wires have voltage at the radio.
When i got the vehicle it already had those wires spliced onto an aftermarket stereo. I dont understand why people do this instead of buying a harness.
On the other hand, i already have this problem. How can i find out if my wires from the car are shorted out?
Some radios also have built in fuses. I know a few of my head units do. But since you said your old radio wouldn't start either, my bet is you screwed up your wiring. Are you sure you are grounding it to clean metal?
First of all thanks to all who contributed on trying to solve my problem.
Stupid me, i didn't check the fuses that are near the steering column. That being said i did find the 15A fuse blown. Replaced it and now i got my stereo working.
vtak2nr
Audio / Security / Video
09-08-2011 08:02 PM
