radio is fuzzy w/ heater on
i posted this here instead of the radio forum because it is specific to my eg, i also have a crvl, and a crx which pick up fine. but when i turn on the radio i get shity reception and when i turn on the fan it gets much much worse. its somewhat bearable on 1 but when i turn the fan up to 2,3,or 4 the station is completely lost. this happens with all stations... and even when i park in the radio station parking lot, it still comes in shitty and the fan blocks it out completely. any help would b appreciated till then im stuck with my old steve earl and nitty gritty dirt band cds
anyone?????
[Modified by hondadazed, 10:54 AM 3/15/2003]
anyone?????
Re: radio is fuzzy w/ heater on (hondadazed)
Ground your headunit independently of the radio wire harness, Its not the best ground. You want to try and keep the new ground as short as possible.
I had a problem with the radio being fuzzy with my lights on. I read this post, went out and ripped everything apart. I hooked my ground wire to a metal bracket in the car. Make sure you clean off the metal before you connect the wire so it'll get better contact.
I just tried it and its 100% better. No more static
Fuster_Cluck
04-19-2003 05:37 PM
