radiator question
Re: radiator question
if you're concerned about interchangeability... they do.
you can go with the sohc one or the dohc one. A lot of people run dual-core rads in the dohc, but a single core will work just fine
yeah I guess that was my question.. my friend needs a radiator for his civic but he got a b18 motor.. I have an extra radiator from (I think) a sohc civic ek.. friend says it won't fit.. I parted out an si for my ek so I'm using the si radiator. I have a radiator idk what it's from because the shell I bought was heavily modded before so it might not be the stock one.. it's goin into a b18 civic, err trying. thanks in advance
he may be able to get away with using 2 hose clamps to make sure it doesn't leak. it's doable, but i wouldn't leave it like that for too long.
Seagull Management
Just to confirm some stuff and make it easier to read:
-B-series civic rads use larger inlets for the rad hoses and are dual core.
-A stock D-series rad will work just fine if you use adjustable gear type hose clamps.
Boostage
06-29-2004 04:41 PM
