Rack & Pinion issues!! Help
Old 07-23-2012, 01:16 PM
BoRiCuA's Avatar
Icon2 Rack & Pinion issues!! Help
95 honda civic Lx 4dr Sedan- w/ABS
So i replaced the Steering Rack without centering my steering wheel, took it for an alignment but steering wheel still not centered (not as bad as before) but still off.
So i loosened up the bolt at the bottom of the steering column that holds the neck of the rack and pinion and start to center my steering wheel boom got it right , well here is where the problem starts.
If i turn my steering wheel to make a circle in either direction (turned all the way) i start to hear metal to metal really bad, what did i do wrong? How can i fix this?
Old 07-23-2012, 02:20 PM
BoRiCuA's Avatar
Default Re: Rack & Pinion issues!! Help
80 views= no replies,guru's where you guys at...........Help
Old 07-23-2012, 02:53 PM
Former User's Avatar
You must also center the cable reel in the steering wheel.
In addition, the steering wheel also can be centered by removing it and reinstalling.
Old 07-23-2012, 03:05 PM
BoRiCuA's Avatar
ok i will remove the steering whell and center it, but what about the metal rubbing when i turn my wheel all the way, it's almost as if my turning ratio has been reduced.....
Old 07-23-2012, 04:20 PM
dwn134@gmail.co's Avatar
have you aligned it yet? if not the tie rods could be to far out of range and wheel hitting something, or have wrong rack installed. where is the sound coming from btw? column, rack or wheels?
Old 07-23-2012, 04:29 PM
BoRiCuA's Avatar
already taken for alignment almost all green except for camber, coming from the wheels when i turn the steering all the way... both sides
Old 07-23-2012, 04:32 PM
Should have added this^ to first post.
Sounds like the wheel splash guards are bent and rubbing on the brake rotor. Bend them away from the rotor.
Old 07-24-2012, 04:28 AM
BoRiCuA's Avatar
I believe i did
Anyways i'll check to see if their rubbing today...thanks
Old 07-24-2012, 05:16 AM
I believe i did
This^ key information was missing.
Old 07-26-2012, 07:32 AM
BoRiCuA's Avatar
ok all done whats the easiest way to center the steering wheel?
Old 07-26-2012, 07:45 AM
Jimster480's Avatar
If its coming from the wheels then it shouldnt be the steering wheel unless its possibly only on one side that its happening. You sure you have the right rack? And do you have any idea what it could be scraping on? Check the parts down there and see if there are any visible signs of rub.
Old 07-26-2012, 11:12 AM
BoRiCuA's Avatar
The problem was i rushed the job of replacing the rack and everything else that i accidently put the tie rods on backwards, left on right and right on left. funny how the people at suntire where i got my alignment done at, didn't pick that up.
Anyways lesson learned don't rush and double check everything!!
Took my steering wheel off just now and everything is A ok.
Old 07-26-2012, 12:11 PM
Jimster480's Avatar
LOL I'd think about taking your car elsewhere for the alignment from now on if they didnt notice that.
civic4life8045
18
06-05-2013 09:10 AM
steadysupreme
03-23-2008 01:04 PM
breanna
02-28-2006 12:51 AM
MenaceAccord92
10-22-2004 06:41 AM
choi830
10-30-2003 05:13 AM
Quick Reply: Rack & Pinion issues!! Help
