Quick wiring question.
i wanna throw some 6x9's in the back of my civic.
so for my rear left speaker i would...
1. Cut the wires(Red/Yellow|Brown/White and Blue/Yellow|Grey/White) from the back of my cd player
2. Connect the cut wires from the DIN to the speaker?
Mind you i have no amp so i am running it off the deck. Is that correct?
My 2nd question is where are the rear speaker wires run to now? I have a 94 CX and i have no rear speakers now.
TIA
This has also been posted in audio/video/security but i got no responces due to the fact that it is more of a cx question?
TIA
Re: Quick wiring question. (Mendes)
you should already have the plugs for rear speakers, pop off the side panel inserts, stick your hand down inside and you should find the plug taped to the support. Next time try the audio forum
Re: Quick wiring question. (hatchdrvr)
that would save so much work. im going to check right now. but i did try the audio forum.. and searched.. no avail. Thanks for the help!
ok just checked and turned up a negative. where should i be looking?
i took of the rear panels (beside the rear seats) and there was no harness like there is for my front door speakers. the wire that runs by there is for the tail lights. i dont see any speaker wires.
hehe i have a dx and i didnt have wires for my rear speakers either.... Why dont you just run the rear speaker wires from the harness??? they're labeled as l.r.speaker and so forth.... gud luck hope that helps
Re: Quick wiring question. (Pnoymugen)
Heh you ARE wired. as was i! they are just hard to find. Search Rear Speakers. that was my problem i searched stero wiring..
Found it and worked! thanks!
